What sensor is this?
Posted: May 14th, 2011, 4:30 pm
by Mariob316
Today while doing spring cleaning car edition I found this unplugged with the connector broken D: Should this be of big concern? If you can't tell it's right beside the alternator
in front of the left rad fan
EDIT: Ok just looked at the workshop manual and it seems to be the oil pressure switch?? Should it be fixed asap?
Re: What sensor is this?
Posted: May 14th, 2011, 6:11 pm
by mitmaks
yes that's oil pressure switch, there should be wire going to it
Posted: May 14th, 2011, 6:18 pm
by muttpower
Would it result in a horrific explosion....no, but should it be fixed???? Yes...your car wont blow up suddenly without it, but I'd still get it fixed...
Posted: May 14th, 2011, 6:21 pm
by mitmaks
this sensor would light up your "oil" light on your dash when oil pressure is low, at least when it's in working condition.
Posted: May 14th, 2011, 6:27 pm
by Mariob316
alright, thanks ahahhaa. Ill get it done tomorrow.
Posted: May 16th, 2011, 11:18 pm
by Pritchett
Or you could swap it out for a proper oil pressure gauge with numbers instead of the stupid light. Just an idea of course.
