Realigning Reverse idler shaft?
Posted: April 9th, 2011, 9:40 pm
So the lock bolt that holds the reverse idler shaft in place fell out at some point and now I can engage every gear easily and smoothly except reverse its a 4 cyl dohc if that helps
Now I sit under the tranny and I can see part of the shaft, and i managed to move it in a way that lets me see about half of the threaded hole for the reverse idler shaft that threads to the lock bolt on the outside of the transmission.... I tried to take a picture but i cant get it to show what im trying to describe lol
Now the problem is I cant get it to move back into alignment with the hole for the lock bolt to thread my new bolt into place and was wondering if there was an easy way to cheat it back into place without taking the transmission apart
If someone could help that'd be sweet
I found this link here:
http://www.mx-3.com/phpBB3/viewtopic.ph ... er#p402218
with pictures (about 8 down) but to me it looks like it should just move back into place
so i guess im missing something...
