ok, I have a little project for college, I need to produce a High Pass filter with the -3dB point at 10kHz, which i've done, however the roll off has to be -12dBs/octave. I dont know how to get the roll off from -3dBs to -12dBs?
I was hoping that somebody here in the Stereo section would be able to advise me!
Geez, there is only one member on here that I can think of that might be able to answer your ?... and I cannot remember his screen name. However, he used to be on here alot mroe often and is a MX-3 stereo badass. So you might see if you can find out who has posted the most in this section over the years. IIRC he lives/d in Mississippi or Louisianna or somewhere over there.
2003 Forester Xti - EJ20K swapped. Feedback
Thanks for thinking I could answer this question. But I never used a passive crossover network. I only use active crossovers. I can guide you to site where someone maybe able to answer it. http://www.diymobileaudio.com/forum/
^ bingo! i know a lot also but man when you get all that technical stuff its a foreign language to me. that is a lot more math and science then i can calculate.
NEUMAN
neuman speeds and neuman drives an escort therefore i am
Featured in SCC Readers Rides March 2005
15.592@ 88.44mph 91egt (when i was n/a)
14.3@ 100mph 91egt(now with "x" power) 209whp/226wtrq
03 - Toyota Matrix XR AWD - 07-current
93 - EGT/323 - 04-current
91 - EGT - 07-current
91 - EGT-X - 01-05
90 - 323hb - 05-07
89 - ELX - 98-00
88 - EGT - 00-01 neuspeedescort - neuman audio car stereo fabrication
