no spark on 1993 mazda mx3 1.6 4 cylinder
i was at the gas station my car was idleing then all of a sudden died so i tried to restart it nothing happens just cranks over and over so i pulled the ignition coil wire not seeing any spark bought a new coil installed it still no spark goin to the distributer checked the fuses they all seem ok i dont know what else to do now what else can cause the car to just died and get no spark ?
- carizle
Re: no spark on 1993 mazda mx3 1.6 4 cylinder
maybe research hei mod or ignition module. seems to be a pretty common problem around here.
If it weren't for physics and law enforcement, I'd be unstoppable!
98 Mustang Gt-convertible, bolt-ons and SCT race tune-Cams and 4.10 gears coming soon
SOLD-92 GS beater-280,000 miles and still goin strong-HEI mod
SOLD-91 Explorer XLT 4x4-never let me down, at least when I can afford to fill it up
- Ryan
1993 is a SOHC, and usually doesn't have ignition issues...
Does it throw a CEL? I'd check that. Ignitor failure often comes with a code 2 or code 3.
http://www.mx-3.com/phpBB3/viewtopic.ph ... C+no+spark
ive replaced the ignition module and it seemed to work great if not better afterwards. was driving on the high way one day and i noticed my car sounding like it was running on 3 cylinders. so i pulled over and popped the hood and a spark plug was missing. i walked back to town . got a spark plug then put it in and continued driving. went and had lunch and about 10 minutes after i left car died when i was going 60 miles per hour. ended up being an ignition module. check ebay found one for 30 bucks
Don't you hate it when one morning, you get up, and a spark plug decides to get up and walk away...
- Ryan
Happened to Jeremy on Top Gear in his Miata when they were over in the middle east.
I don't understand how a plug... just falls out.
- carizle
Indeed, I remebered that when I went to post it, but it just popped out, but didn't run away or anythingRyan wrote:Happened to Jeremy on Top Gear in his Miata when they were over in the middle east.
