DIY Autotune PNP ECU for V6?
Posted: January 25th, 2011, 9:37 am
by war_spider
hello,
found nothing special at the search
does the V6 is really compatible with the DIY Autotune ECU? Miata 4cyl ok but the same ECU for the V6?
http://www.diyautotune.com/catalog/diyp ... p-384.html
someone bought one of these and its running?
Re: DIY Autotune PNP ECU for V6?
Posted: January 29th, 2011, 12:00 am
by Nd4SpdSe
Also known as "Megasquirt"
Posted: January 29th, 2011, 2:52 am
by wytbishop
They're just selling technology that's been around for a long time. The difference with them, for a price, they will assemble a computer that you can plug your standard engine harness into just like stock. You would only have to run a couple of wires.
When you build a Megasquirt computer yourself you have to assemble the ECU and wire in all the inputs yourself...not so bad, but lots of people are willing to pay someone to make a plug and play unit.
Posted: February 26th, 2011, 6:28 pm
by RedAutobotMX3
So this has the potential of Megasquirt, but its all ready to go, just swap out the ecu and ground it out?
Posted: February 26th, 2011, 10:49 pm
by Nd4SpdSe
RedAutobotMX3 wrote:So this has the potential of Megasquirt
That
IS Megasquirt
Posted: February 28th, 2011, 10:19 am
by wytbishop
Ya see...what they do is...they take one of them there MegaSquirt kits...and then they buy themselves a Nippon Denso female harness plug that matches the Mazda wire harness...see...and they assemble it so's you can remove your stock ECU...and plug in the MS ECU...and it'll just, work. Provided of course that you's have installed the appropriate IAT sensor and such like.
Proven technology with slightly more convenient packaging.
Posted: February 28th, 2011, 12:12 pm
by Daninski
wytbishop does redneck. Never thought I'd live to see that.
You just have to make sure you have a cam sensor in your disty. Megasquirt uses that. Our 92-93s have them, not sure on 94, 95-96 no cam sensor so. If you don't have a disty with a cam sensor you need to get one and swap it for yours being careful that the 3 wire plug wires are in the proper order at the disty. (see HEI mod in FAQ section)
Posted: October 9th, 2011, 3:25 pm
by hgallegos915
HMMM I wonder if that wiring connector is ONLY compatible with their megasquirt or if it will work with the one I got from shadowme..
Posted: October 9th, 2011, 5:29 pm
by marcdh
Daninski wrote:wytbishop does redneck. Never thought I'd live to see that.
Or get a 36-1 626 crank pulley (and coilpacks and bin that POS disty
Or grind a tooth off your stock pulley
Posted: October 9th, 2011, 5:31 pm
by wytbishop
The connector they wire into the MS unit is just the same connector that Mazda uses to make the stock ECU. To use it with your homemade MS unit you would just have to kwow what wires go to which terminals and wire it in.
