Two Questions
- MattGlaceBayCanada
Two Questions
ive orderer my motor for my swap klze curve neck manifold. i have two questions . How much trouble would it to use that curve neck manifold if i could . And which woul be my best bet install a probinator chip in my exsisting ecu or use a 93-97 ford probe/mx6 ecu and vaf?
Re: Two Questions
Curved neck...good
Probinator...better than probe ECU/VAF. Easiest, but debatable if it's the best. Definitely most common.
Re: Two Questions
you would have no trouble using your current ecu + probnator and the curved neck manifold.
i think some people have gotten a better fuel mixture usin a probe ecu and vaf, but the majority see better results with mx3 ecu + probinator.
theres alot of threads on this topic, do some searching and decide for yourself which is best.
- MrMazda92
Re: Two Questions
All these suggestions are good, yet MSnS > All of them
Go big!
Go big!
Re: Two Questions
Probinator is good just be prepared to wait for Ryan to respond.
