Through the mx6 club i found a website that sells all sorts of suspension parts for the mx6 and ford probe.
Most of these look like they might fit on the mx3 too:
Www.king6fab.com
Has anyone ever ordered anything from them?
I'm especially interested in the rear performance swaybar and traction bars.
I contacted him to ask if he knew it whould fit, but he didn't know.. He asked me for some measurements, which I'm going to provide him asap.
K6f suspension parts
Re: K6f suspension parts
The Probe/MX-6 control arms are significantly different from ours. I'm not certain of their bushing dimensions, but I would be shocked if they'd fit. The front motor mount will fit, same as the AWR mount does, but the Probe frame is totally different from ours as well, so the other mounts definitely won't fit.
I know, thats why he asked the dimensions of a mx3. The tractionbar is just a bar with two bushings on each end. Only difference with the mx6 is that the mx6 is longer. Cant be that hard for him to produce shorter ones. Same with the swaybar..wytbishop wrote:The Probe/MX-6 control arms are significantly different from ours. I'm not certain of their bushing dimensions, but I would be shocked if they'd fit. The front motor mount will fit, same as the AWR mount does, but the Probe frame is totally different from ours as well, so the other mounts definitely won't fit.
