anyways to my question, I've got an aftermarket shifter knob/boot that don't quite fit, so the knob spins freely and the boot just kind of sits there without a real purpose... has anyone come across and fixed this problem?
AM shifter knob/boot
- SteeleMX3
Hi all, I've finally made my return to the world of driving after a vicious few months of financial strife that literally ended right before christmas. My baby is insured, registered, and rockin once more
and obviously I'm now back to fixing her up.
1992 Mazda MX3 Precidia GS-KLZE :: Rockin' my world since 2009
viewtopic.php?f=46&t=72989 ---> Workloooogg
Re: AM shifter knob/boot
The B&M knob comes with plastic adapters that screw onto
short shifters. The adapter is female with male over top and allows
for the knob to be then securely screwed on.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
- SteeleMX3
but that means ive got to get a short shifter
Is there something that will fit my AM knob to the OEM shifter?
- solo_ryder
Superglue.
- hotsiit
You can try wrapping the threaded part of the shifter with electrical tape, and then spin the knob on. may take a while until you figure out how much tape is needed to get a snug fit. Not really a permanent solution, but has worked OK for me.
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
I've never been a fan of aftermarket shift knobs... seems like they stay tight for a little while but eventually will come loose. The kind I had used a tiny little allen screw to hold it tight to the shifter...
- SteeleMX3
ye that's exactly what happened with this one, those little screws just goudged the shifter and came loose after a week. I think I'll try the electtrical tape for now, cheers hotsiit.Mooneggs wrote:I've never been a fan of aftermarket shift knobs... seems like they stay tight for a little while but eventually will come loose. The kind I had used a tiny little allen screw to hold it tight to the shifter...
mikeinaus
hot glue.., id fill the knob with hot glue and put it on your shifter. should hold for quite a while but be fairly easily to remove and clean up if you want to change knobs down the road. try it if the tape doesnt work.
p.s. i was wondering what happened to you
- SteeleMX3
that actually sounds like a really good idea, cheers man. And thanks haha, at least someone noticed I dropped off the face of the Earthmikeinaus wrote:hot glue.., id fill the knob with hot glue and put it on your shifter. should hold for quite a while but be fairly easily to remove and clean up if you want to change knobs down the road. try it if the tape doesnt work.
- MrMazda92
SteeleMX3 wrote:ye that's exactly what happened with this one, those little screws just goudged the shifter and came loose after a week. I think I'll try the electtrical tape for now, cheers hotsiit.Mooneggs wrote:I've never been a fan of aftermarket shift knobs... seems like they stay tight for a little while but eventually will come loose. The kind I had used a tiny little allen screw to hold it tight to the shifter...
Tip time ;D
Keep the setup it came with, with the little allen screw. Drill into your shifter slightly, just to give it a little recess for the screw to go into, tap it if you've the patience. If you don't, put the glue in the recess, then tighten the screw down.
Other than that... make a custom shift knob. ;D
