Reverse lights don't come on?
Posted: November 9th, 2010, 10:01 pm
by bbunkerc397
Never really noticed but when I put my car in reverse the lights don't come on any suggestion?
Re: Reverse lights don't come on?
Posted: November 9th, 2010, 10:12 pm
by _-Night-Shade-_
Reverse switch.
Posted: November 9th, 2010, 10:20 pm
by bbunkerc397
where is it located on the tranny?
Posted: November 9th, 2010, 10:28 pm
by Evo_Spec
if you look down under the air box (or where it used to be, if you have a CAI) it should be right around there on the underside of the tranny (closest to you).
if that made any sense...
Posted: November 10th, 2010, 12:26 am
by _-Night-Shade-_
It's a PITA with the engine/tranny in the car. I had to swap sensors over because I have PGT tranny and I didn't tighten it good enough at first so my reverse lights wouldn't come on. Man it was a b*tch tightening it a milimeter at a time. It needs to be in there TIGHT.
Posted: November 10th, 2010, 9:16 pm
by bbunkerc397
hmmm, I'm going to look at it tomorrow.
Posted: December 21st, 2010, 1:13 pm
by john1983
i have a problem kinda like this when i put my car in reverse only one light comes on and i know its not the bulb and for some reason only my led bulbs want to work but i dont think i can use them for they are red
Posted: December 21st, 2010, 1:22 pm
by wytbishop
_-Night-Shade-_ wrote:It's a PITA with the engine/tranny in the car. I had to swap sensors over because I have PGT tranny and I didn't tighten it good enough at first so my reverse lights wouldn't come on. Man it was a b*tch tightening it a milimeter at a time. It needs to be in there TIGHT.
I don't understand why this caused you so much difficulty. It's right in the front of the tranny case and in my experience has never been difficult to tighten down. I changed mine without even draining the tranny once.
