Recommend a clutch for KLZE
Lesley
Post by Lesley »
Hey guys...
My KLZE arrived today (30,000 miles, really clean!).
Can you recommend a good clutch kit?
I will be doing some lapping at Mosport.
Thanks!
92 Mx3 GS KLZE 5 speed
97 Dodge Dakota - Boyd rims, custom built 5.9 360, custom tranny with kevlar guts and shift kit. Too many upgrades to list.
92 Mazda 323 - winter beater
mx3 by Leadfoot Lesley, on Flickr
Ryan
Re: Recommend a clutch for KLZE
Post by Ryan »
Centerforce, ACT, bully, South Bend, Clutchmasters.... all good brands. pick one for your application ~50HP over your range, so rated for 250 HP, or 200 ft lbs...
_-Night-Shade-_
Post by _-Night-Shade-_ »
Don't forget Spec.
mikeinaus
Post by mikeinaus »
exedy is good and cheap...
solo_ryder
Post by solo_ryder »
Spec is good, Exedy OEM probe clutch is cheappppp and holds up very well, numerous ppl including myself have had success with them. You can get em cheap on ebay with all the parts and bearings
Lesley
Post by Lesley »
I wondered about the Exedy, since there are a lot of them on Ebay. Have any of you guys used them in motorsports, like autocross, or lapping?
The ACT kits are pretty dear from what I see.
mikeinaus
Post by mikeinaus »
youd probably want atleast a stage 1 or stage 2 for autocross. for daily driving id say the oem would be fine but constantly dropping the clutch at high rpms may burn it out fairly quickly.
Lesley
Post by Lesley »
Yeah, that's what I was thinking. Probably do more lapping than autocross, but there are some hard braking and downshifting spots in track too.
The ACT kit on ebay sounds good, but they sure like to ding you for shipping.
solo_ryder
Lesley wrote:Yeah, that's what I was thinking. Probably do more lapping than autocross, but there are some hard braking and downshifting spots in track too.
Exedy will hold up, just ask nd4spd.
I am not easy on my clutch either and i broke it in for about 7km and its still not slipping after at least 60k.
ACT is a good bet as well
PATDIESEL
Post by PATDIESEL »
I am happy to see you post Leslie, been a bit. I used to run a ACT and it was pretty nice, but has a quick engagement. After some practice I bet you'll find yourself wanting somthing that engages a bit more smoothly. The quick transition makes it hard to ease into the gear on corner exit and thus you do so late and loose some MPH. For a FWD that is imparative. I would recommend Spec or Clutch Masters. I've not driven a Spec on a ZE, but on a BP they are great. The CM I use now is great also. I've only put one season on it, but so far I like it better than the old ACT. Plus, for the price of a ACT plus a couple bucks you can get a CM and aluminum flywheel from Rafi at R&R Racing (if he is still in business, I might have heard he shut down his parts sales).
Lesley
Post by Lesley »
Thanks so much for the advice... now that I'm having some fun with my MX, I'll have to visit your board some more :-)
I looked at the price of an ACT clutch kit and flywheel, almost what I paid for the engine!
I'll look into the Spec and Clutchmasters you recommended :mrgreen:
solo_ryder
PATDIESEL wrote:I am happy to see you post Leslie, been a bit. I used to run a ACT and it was pretty nice, but has a quick engagement. After some practice I bet you'll find yourself wanting somthing that engages a bit more smoothly. The quick transition makes it hard to ease into the gear on corner exit and thus you do so late and loose some MPH. For a FWD that is imparative. I would recommend Spec or Clutch Masters. I've not driven a Spec on a ZE, but on a BP they are great. The CM I use now is great also. I've only put one season on it, but so far I like it better than the old ACT. Plus, for the price of a ACT plus a couple bucks you can get a CM and aluminum flywheel from Rafi at R&R Racing (if he is still in business, I might have heard he shut down his parts sales).
Hey Pat you got the FX100? I have one of these sitting at my parents place and I was pondering if it would be worth putting in when I replace my tranny next spring
solo_ryder wrote:Exedy will hold up, just ask nd4spd.
Never ran Exedy, I had a Bully Stage 2 and it was awesome, but many of the local guys ran the Exedy and never had any problems with them, even with the abuse they took.
solo_ryder
I think that is the like the 3rd time I have said you ran one but I know you didnt. Im losing my mind
Lesley
Post by Lesley »
RR Racing is indeed still in business. Talked to Rafi, the price for a clutch kit and the flywheel is only marginally more than the ACT kit + delivery.
There are a couple of Clutchmaster Stage II kits on ebay that look reasonable, depends on whether i can get a flywheel deal too.
