Thanx for any input.
kateCapshaw wrote:The moment somebody says to me, "This is very risky," is the moment it becomes attractive to me.
Totally forgot about the water pump! xD Although I don't think its the pump. When the weephole starts weeping its normally noticeable because it'll release a small pool onto your driveway. He's not getting any leaks or anything. Might be a pressure issue but that's normally pretty noticeable too.Sleeper6 wrote:Also be sure to shine a light up from underneath at the water pump to check the weaphole for moisture. Its the pulley dead center of your engine above the main drive pully ( your harmonic balencer). Either way its still an easy afternoon job at the worst
