Page 1 of 2
Doors Don't Stay Locked
Posted: October 27th, 2010, 12:20 pm
by Sisko182
I used the search function, but unfortunately didn't find anything that pertains to my exact problem.
When I lock my doors, whether it be from the inside, or close the door and lock the doors with the key, when I pull on the handle, it unlocks automatically. This is obviously a problem, considering anyone could just come up and open my door and get in my car no problem.
Done driving the mx3 for this season, since we just had a huge snow storm yesterday, so I have time to work on it. What could the problem be and how could I go about fixing it?
Thanks.
Re: Doors Don't Stay Locked
Posted: October 27th, 2010, 1:17 pm
by Savin
Are your locks hooked up? Also, you have to hold up on the outside handle when closing the door. If you don't, it will automatically unlock.
Posted: October 27th, 2010, 4:23 pm
by Sisko182
Savin wrote:Are your locks hooked up? Also, you have to hold up on the outside handle when closing the door. If you don't, it will automatically unlock.
Yes they're hooked up. When I lock the driver side, the passenger side locks as well, etc.
Like I said, even when i lock the door using the key, it unlocks when I pull on the handle. Pretty strange.
Posted: October 27th, 2010, 6:34 pm
by Ryan
You're going to have to open the door and look for bent/seized actuator rods. I have a good idea of which one is seized... you should be able to figure out how it works.
Posted: November 3rd, 2010, 10:38 pm
by Sisko182
Solved my problem. Managed to fix the seized actuator rod (so you were right on that one), so now, the door stays locked when I hold the handle up and then close it.
Posted: November 5th, 2010, 3:20 am
by MrMazda92
Uhhh... Mine doesn't require that :/
Also, my passenger side can only be locked when it is shut. Shutting the door unlocks it, no matter what method I use to lock it. It's not a seized/bent rod, I've torn it apart multiple times in frustration, and honestly can't figure it out. I honestly do hate having to be impatient with anyone riding in my car, making them get out and shut the door so I can lock the car and get on with my day.
Edit: Previous owner was an idiot, the PS door requires the handle to be held.
Posted: November 5th, 2010, 11:42 am
by Ryan
That doesn't make much sense.
You hold up the handle, close the door, release the handle.
If that isn't working, something is broken/bent.
Posted: November 8th, 2010, 2:58 am
by MrMazda92
Ryan wrote:That doesn't make much sense.
I'll explain:
My DS door locks and closes without touching the exterior handle, no issues.
My passenger door requires the typical driver side door method to close.
The good news is, I have a minty PS door with handle and assembly. I'll swap the locks and install it as-is, thus having no silly handle pull required on either door.
Posted: November 8th, 2010, 3:19 am
by Sisko182
MrMazda92 wrote:Ryan wrote:That doesn't make much sense.
I'll explain:
Its not really silly - its a feature meant so that you don't lock your keys in your car.
Posted: November 8th, 2010, 3:28 am
by MrMazda92
I understand the intended purpose, however I simply don't do that
I locked my keys in the car once while it was running when I was 17, it was my mother's grocery getter. I had a 10 mile run(home and back) burned into my memory, I simply haven't repeated the mistake. Also, I'm putting a keypad on my car this winter.
Posted: November 8th, 2010, 1:38 pm
by Evo_Spec
I'll explain:
mine does that too, the passenger side requires the handle held but not the driver side
Posted: November 8th, 2010, 3:51 pm
by Sisko182
Both doors on my car require the handle to be held up.
Posted: November 8th, 2010, 10:41 pm
by MrMazda92
Weird, I hadn't noticed that on any of the MX-3s I've driven. :/
Posted: November 19th, 2010, 12:34 pm
by Dragon1212
Sisko182 wrote:MrMazda92 wrote:Ryan wrote:That doesn't make much sense.
I'll explain:
I know... It Never works I always remember to lift the handle and always forget my keys. Funny how that works huh
Posted: November 20th, 2010, 3:53 am
by ethand
Sisko182 wrote:Both doors on my car require the handle to be held up.
Ditto. and
Dragon1212 wrote:I know... It Never works I always remember to lift the handle and always forget my keys. Funny how that works huh
Ditto again...
