If anyone has a front hub laying around which is not installed in the steering knuckle and wouldn't mind taking some measurements for me I would be much obliged.
If you have one and can do it contact me and I'll send a drawing that you can record dimensions on.
Thanks for your help.
DImensions of the front hub
- umcamara
Re: DImensions of the front hub
I'm assuming someone will have one. But if not, did you try your parts store. If they have one in stock, I can't see why they wouldn't let you measure it, to "make sure it's going to fit your car".
I tried...no one stocks it. And they won't order it in without deposit and it's waaaay overpriced.
Well not sure if this helps but
http://www.dormanproducts.com/da-16681-930-550.aspx" onclick="window.open(this.href);return false;
Its $34 so not that bad but if you need specs I can order one and have it monday by lunch to measure and send it back, Beauty of working in parts.
Also have this if it helps for the bearing:
Part Number 510003
Inner Diameter 1.5748
Outer Diameter 2.9134
Width 1.5748
Inner Race Radius 0.1496
Outer Race Radius 0.0591
Series FWDB
Desc Radial Ball
Part Number 510003
Width 1.5748
Series FWDB
Desc Radial Ball
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Hey if you could bring one in and measure it you would really be helping me out. I will send you a drawing to mark up.
It's not a fitment question. I'm trying to model it and I need accurate measurements. I have the knuckle and the bearing and the rotor modeled already. The hub is holding me back and it's very important because it determines the position of the rotor with respect to the knuckle.
Send me an email address or something and I'll send you a drawing.
Thanks.
Thanks.
- _-Night-Shade-_
Nightshade to the rescue
Let me know what you need, I've got one - remnant from all my failed wheel bearings lol.
![Cool 8)](./images/smilies/icon_cool.gif)
If you have a pair of them and they're cheap to ship I might take them off your hands. Hit me up and let me know cost with shipping to T6M 0A4. I would prefer to get dimensions off of a new part though as accuracy is sort of critical here.
thanks
thanks
