car bogs when making right turns only
- popcornguy
hello all. im new at this so bear with me.. i have a 1993 mx-3 and when i get to about half tank, my car will bog down when making a right hand turn if im still on the gas peddle. im only 21 so i dont know exactly where to start. i have only had the car about 2 mths. and im very confused
it is a 4cyl and a 5 speed man. any suggestions on where to start? thanks all
Sleeper6
Re: car bogs when making right turns only
I would think a tank baffle is broken or possibly a pump issue. Did anyone change a pump in it before you got it, if so maybe they broke one of the baffles inside the tank, otherwise take a look and see if you have any wires pinching under the dash when your turning the wheel, maybe something got wired in?
Hopefully it helps, thats just where I would start from
- popcornguy
yeah idk if anyone changed anything on this car. it all kinda looks original. but i will do that:) thnx
Demonic1
I'd vote for the gas pump/baffle setup. I changed my pump out (cheap replacement) when I swapped my engine and ever since, if I take a sharp right turn at high speed it bogs out like it has no gas in it.
I have a 135 degree turn before my house, and if I take that at anything more than 60 I can bog it out with a FULL tank.
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
baffle/pump 100%
Egt pumps are notorious for that crap
Somethingabout the pump/pickup
You wouldn't have this problem if you were in NASCAR.
Daninski wrote:You wouldn't have this problem if you were in NASCAR.
haha why, because of the left turn only, or the badass fuel cells they use in the cars
- popcornguy
well i found out what it was. there was a screen catcher on the pump that had fallen off. but thnx so much for your assistance
