hi ive been searching all over for an ecu for my b6 5speed autozam..........i found a sticker on the old ecu with a part number tht was fairly worn...it looked something like b587 18881? last digit/letter is unknown.....evrywhere i look for a b587 ecu returns no result, can someone correct me on if this is the right #? or give me an idea of a compatible ecu.....
also it is DOHC and there are 3 plugs for the ecu
Need 3 plug ecu for B6 5speed autozam....cant get a part#
- RS_OBD'oh_2
Re: Need 3 plug ecu for B6 5speed autozam....cant get a part
J spec?
E spec?
year?
don't know my autozams... give as much info as you can. Post pics etc.
you sure it's a b6 not a b5?
E spec?
year?
