Page 1 of 2
GTR BPT engine swap in 93 MX3 engine harness problems
Posted: September 8th, 2010, 1:27 am
by rusty
Re: GTR BPT engine swap in 93 MX3 engine harness problems
Posted: September 8th, 2010, 12:20 pm
by Ryan
Both the white and black MX-3 connectors go up into the dash harness.
It looks like both of the black connectors match. You may have to splice over the other plug.... is there a GTR engine harness diagram on CP?
Engine will run still, I think, but nothing else will work...
Posted: September 8th, 2010, 12:25 pm
by rusty
The GTR white connector will not plug in as its too big. Like i said the GTR connector is a 15 pin and the MX3 is a 10 pin
Posted: September 8th, 2010, 1:45 pm
by Ryan
Thats what I said/meant... The black one looks fine, its just the white one that needs to be spliced over, unless you can get your hands on the GTR dash harness.
Posted: September 8th, 2010, 2:31 pm
by rusty
Ok right i found a wiring diagram for the GTR on CP but the wiring colours in the connector don't match up with what i have. The connector is the same put just not the colours of the wiring or the locations. I also need to find a mazda wiring diagram for a 93 MX3 SOHC 1.6L so i can figure out which wire does what.
Posted: September 8th, 2010, 7:26 pm
by Evo_Spec
hope this works out for you, post pictures of the swap! (unless i missed it somewhere)
Posted: December 4th, 2010, 3:36 am
by cricketol2
deleted
Posted: December 4th, 2010, 4:00 am
by cricketol2
i found your page on cp but im lost . i dont have the book was wondering if you could help out by any chance
i have a sohc and im swapping a bpt and was wondering if you could help me out with the splicing diagram i have color coding but how does it help with the rest
please help me out.
Posted: December 4th, 2010, 1:16 pm
by rusty
Well i got my gtr installed and running in my MX3 but the harness was my biggest issue. It was no easy task. First off the GTR and GTX harness is about 3 feet shorter then the MX3 cause it from a right hand drive car and would go threw the firewall on the left and side of the car. Where as the engine harness for the MX3 goes thew the firewall on the right had side of the car. It took me weeks of studying the two wiring diagrams MX3 and GTR to figure out which plugs i had to switch to make it work. Plus i also had to lengthen the complete harness. Do you have a GTX harness already?
Posted: December 4th, 2010, 4:23 pm
by rusty
yes you will have to replace the GTR 15 pin white connector with your mx3 10 pin white connector on the gtr/gtx harness. As well as move some wires around in the 20 pin black connector. plus lengthen the harness if this is the route you wanna go. Everyone told me to use a protege 1.8L DOHC harness but its has the same 15 pin white and 20 pin black connectors as the GTR/GTX and won't plug into your car either. Plus all the plugs on the protege harness don't match up with the GTR/GTX harness
Posted: December 4th, 2010, 6:21 pm
by Nd4SpdSe
rusty wrote:yes you will have to replace the GTR 15 pin white connector with your mx3 10 pin white connector on the gtr/gtx harness. As well as move some wires around in the 20 pin black connector. plus lengthen the harness if this is the route you wanna go. Everyone told me to use a protege 1.8L DOHC harness but its has the same 15 pin white and 20 pin black connectors as the GTR/GTX and won't plug into your car either. Plus all the plugs on the protege harness don't match up with the GTR/GTX harness
Lol, so you not realise that that spammer literally copy and pasted what YOU wrote? lol
Posted: December 4th, 2010, 8:59 pm
by cricketol2
rusty what all did you use to find out what the wires did and went to.
im in need of that info as well and i have a gtx harness that came with the engine
Posted: December 4th, 2010, 9:47 pm
by cricketol2
Posted: December 5th, 2010, 3:41 am
by rusty
Well this will help you with some of the wiring, which colours do what. These are your two yellow connectors that go into the ECU but the wiring colours will help you establish what they are for
http://www.323gtr.net/323gtr/html/Image ... Wiring.JPG
Posted: December 5th, 2010, 3:45 am
by rusty
If you PM me your email address i can forward you a PDF format MX3 wiring diagram
