Missing Link???
BoostAllDay
Missing Link???
Post by BoostAllDay »
So I'm not sure if my 1.6 DOHC has a map sensor since its OBD1 but if it does have a map sensor then where is it located on my 1994 mx3?? I'm boosting my car so I need to know if I need to run a missing link or not. Please help me out guys.
Thankyou so much for any help!!!
h3xt0r
Re: Missing Link???
Post by h3xt0r »
To be perfectly honest I don't believe the 1.6's had a MAP sensor. I did some looking around and all I can find is after market parts and what have you but no information about a stock one. So my best guess is that there is none, but I could be mistaken.
-H3xT0r
kateCapshaw wrote:The moment somebody says to me, "This is very risky," is the moment it becomes attractive to me.
RS_OBD'oh_2
Re: Missing Link???
Post by RS_OBD'oh_2 »
It does not have a map, it has a maf... and a missing link may be the wrong way to go. There are lots of different ways to boost the b6.
Here is my build to give you some ideas.
http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=69074" onclick="window.open(this.href);return false;
BoostAllDay
Re: Missing Link???
Thanks a lot for the help guys. I've looked at your build many times for different fittings that I needed and I also am using the same header kit from jgs as you did. What did you do about the egr tube going into the stock exhaust manifold??
RS_OBD'oh_2
Re: Missing Link???
the egr is just capped for now. It's not really causing an issue even on the OBD2. I've pulled the egr code maybe twice since I've been boosted. I keep my code reader in the car and just clear it. Problem solved. Will make a block off plate in the future.
BoostAllDay
Re: Missing Link???
Okay cool because I don't see a need for it to be hooked back up
RS_OBD'oh_2
Re: Missing Link???
Where is the worklog man? I'd like to see more boosted b6's
BoostAllDay
Re: Missing Link???
I'm actually gonna start a thread possibly today.
Return to “Forced Induction”
