Which short shifters fit Corksport Bronzoil Bushings?
I've had a pacesetter adjustable short shifter for a few years, and finally got around to changing out the bushings for the bronzoil ones from Corksport. The bushings are way too small for the pacesetter shifter. Which short shifter will these bushings fit?
Matt Domenick
1993 GS-ZE
1993 GS-ZE
Re: Which short shifters fit Corksport Bronzoil Bushings?
I believe they fit the stock shifter, the B&M and the TWM short shifters... I would much rather have a lower shifter and the stock bushings seems to work fine for the pacesetter.
I still use the bronzoil bushings in the 3rd link...
The pacesetter bushings were torn up and corroded pretty badly. I bought the bronzoil bushings not realizing they were a different size. I made an insert out of 3/4" copper pipe, but there is still too much play in the shifter for my liking.
Does anyone have any info on the cheapo shifters for sale on ebay?
Matt Domenick
1993 GS-ZE
1993 GS-ZE
- solo_ryder
The ebay shifters are basically a carbon copy of the oem ones beside the fact it has a shorter throw. Bronzoils wil lwork in em
- MrMazda92
Dibbs on your pacesetter if you decide to let it go. XDSE MX-3 wrote:The pacesetter bushings were torn up and corroded pretty badly. I bought the bronzoil bushings not realizing they were a different size. I made an insert out of 3/4" copper pipe, but there is still too much play in the shifter for my liking.
PM'd, on same subject.
