Stainless Steel Doorsills!
- MrMazda92
Hey guys, I've talked to a few of you about the stainless sills, and my potential for having them made.
I'm not ready to try a group buy, but I AM ready to take the idea to a friend who can make them.
Will my plastic sills be a suitable template? If not, what exactly would I need?
Also, if it pans out I will properly setup a group guy.
- _-Night-Shade-_
Re: Stainless Steel Doorsills!
They are exactly the same other than material and the MX-3 logo on the SS ones.
Have you seen the SS ones, there's more than just SS.
- _-Night-Shade-_
Yes I have, they are right here: viewtopic.php?f=48&t=74557" onclick="window.open(this.href);return false; Plus you have them, Joe has them, prolly seen others with them as well.
Okay, they have screw holes too
Take a close look.
- MrMazda92
Okay... since nobody seems to have any kind of template. :/
Would anyone be willing to send me ONE Stainless doorsill? I'll paypal you collateral, as long as it's reasonable. It'd be easiest if someone in Portland/Vancouver could loan me one, as I'll be up there tomorrow or the next day.
- _-Night-Shade-_
Bro the shape is exactly the same, you can use the stock one just get the MX-3 logo on there.
- MrMazda92
Is the thickness 100% matched? I would rather avoid paying for a few sets, then finding out our doors don't close properly, or some other unforeseen mistake. :S_-Night-Shade-_ wrote:Bro the shape is exactly the same, you can use the stock one just get the MX-3 logo on there.
I don't do anything half assed, it has to be 100%. If I do this, you won't know the difference between OEM and these.
Not sure what the problem is... if you use the stock as a template, you should have no clearance issues. Like _-Night-Shade-_ said, use the stock as a template and add MX-3 logo.MrMazda92 wrote:Is the thickness 100% matched? I would rather avoid paying for a few sets, then finding out our doors don't close properly, or some other unforeseen mistake. :S_-Night-Shade-_ wrote:Bro the shape is exactly the same, you can use the stock one just get the MX-3 logo on there.
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
My SS ones are thin as s---. Like PAPER thin. But like above ^ stock plastic ones fit so you have some leeway to play around with. I myself would like if the SS ones were thicker to handle a little extra abuse.
Took the bp+t out of the mx and swapped it into a 95 escort wagon.
The stainless ones have a rubber/plastic gasket under them.
- MrMazda92
I have an idea.
Who would like me to have them made the stock thickness with the Mx3 and nothing changed?
Put a 1 at the start of your reply if this works for you.
Who would like me to have them slightly thicker with the Mx3, no change besides thickness?
Put a 2 at the start of your reply if this works for you.
Who would like a change in the design, with added thickness and any other changes?
Put a 3 at the start of your reply, and post suggestions that you feel would be beneficial.
I dont care either way, I already have a set.
But, cant you add a poll to your first post with those options?
- _-Night-Shade-_
1
@ pox: polls don't work at the moment.
- MrMazda92
Thinner = Likely Cheaper, is this your logic as well?_-Night-Shade-_ wrote:1
You're correct on the polls too, that's why I didn't waste my time.
