Unknown 1 wire connector?
Posted: April 13th, 2010, 10:07 pm
by Mariob316
While cleaning up my engs?ine bay today i found this just hanging there, its all the way to the firewall on the passenger side. It only 1 wire, any idea where it goes or if it's important. I have a 94' gs
http://img717.imageshack.us/img717/8369/sspx0128.jpg The pic is kinda big, so here is the link to it
Re: Unknown 1 wire connector?
Posted: April 13th, 2010, 10:22 pm
by solo_ryder
That plug is related to the air con IIRC. They are installed on all mx3's even if you do not have air con. It is not motor related.
Posted: April 13th, 2010, 10:28 pm
by Mariob316
I do have air conditioning tho which seems to work fine. But anyways if it's not important i shall just leave it. Thanks for the info
Posted: April 13th, 2010, 11:35 pm
by _-Night-Shade-_
Yeah I think I saw that too when I was plugging everything in after my swap. Doesn't go anywhere, for me at least - I don't have AC.
Posted: April 14th, 2010, 11:58 am
by cout
Can you tell what color the wire is and if it's striped? The wires seem to be very nicely color coded in the mx3 (a welcome change from other cars I've worked on).
Posted: April 14th, 2010, 12:56 pm
by Daninski
I can't pull your pic up but check to make sure the one wire plug is on your PS pump.
Posted: April 14th, 2010, 3:32 pm
by solo_ryder
Daninski wrote:I can't pull your pic up but check to make sure the one wire plug is on your PS pump.
Its not the ps wire. Its connected to the body (white connector) under the relays on the ps
Posted: April 14th, 2010, 10:12 pm
by Mariob316
i've made the pic smaller, like solo said, its like a white-ish color
