I've had my MX3 since December 09
V6 1.8L 5speed w/ cruise.
While driving at highway speeds (sometimes in excess of 140KMh) I get a Check Engine Light, sometimes it flashes, sometimes it stays lit. I have a OBD reader, but never have it with me when it happens.
Mechanic friend says high speed misfire. Anyone have any other reasons / causes?
CEL @ 140KMh
- Eckz
CEL @ 140KMh
'98 Escort ZX2, Red, 5 Speed, HotShot Intake, Factory Stereo (robbed of a Dual in-dash DVD), GT Hub w/ Pilot GT Steering Wheel
Upcoming: Body Work
2Litre Rice Eater
'95 MX-3 Precidia GS, White, 5 Speed, Stock V6 1.8L, JVC Double-Din, MTX JackHammer AMP, MTX JackHammer 10" x2, Halo Projectors w/ 6K HID Kit
Upcoming: Air Intake / Body Work
Upcoming: Body Work
2Litre Rice Eater
- solo_ryder
Re: CEL @ 140KMh
Mechanic is proly right.
What r u gonna plug in the reader while going over 140?? Lol. Even if the light went on then off it should still be saved in memory. Get the reader on there
- Ryan
Re: CEL @ 140KMh
Car doesn't give a rip how fast its going.
Its the RPM's and the load. Should happen in any gear at same rpm's under similar load.
Re: CEL @ 140KMh
There are soft codes that won't stay in the ECU. Try holding the rpm up for a few minutes and see if you can simulate the problem. Misfires can be a tricky issue. Google misfires as there's lots of info out there on that particular problem
