[FS] (CA)The last of my Mazda stuff!
- GreenMachine
here we go.
I have 2 sets of mazda valve covers. $20 each
3 throttle bodies, i believe a KLZE KLDE and a K8. $30
KLDE intake mani w/ injectors, rail everything in pic. $25
k8 intake mani w/ injectors, rails, everything in pic. $25
unorthadox racing aluminum crank pulley. $30
Amber front turn indicators/signals. $10
Teal front fenders off of a gs. $25 for passenger, driver fender gone
Best way to get a hold of me is email, but I periodically check in here.
static_x_@hotmail.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
-Chris
-Chris
Last edited by GreenMachine on April 13th, 2010, 1:17 pm, edited 2 times in total.
'92 GS-no lip. Klze. no cat. phenolic spacers. no power steering. no a/c. hei mod. poly filled mounts. probinator chip. loud exhaust. b&m shifter. tokico struts. suspension tech springs. axxis 17 in rims.
'86 mr2-stock and still hauls a-- in curves.
'05 Gsxr-50 tooth stunt bike
- Dali
Re: [FS] (CA)The last of my Mazda stuff!
email sent for pulley and fender (maybe).
1993 White gs klze.
- fowljesse
OH, man! I've been waiting for an UDP. I'll be 2nd in line, if the deal doesn't go through.
Email sent for spoiler and fender
- 2fazed
Emailed about the spoiler. Man it's weird since that spoiler and fenders used to be mine.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
- GreenMachine
wrap around and drivers side fender gone. everything else still available.
Hey random Q, does your Underdrive pulley have a lip on the back side? If so I had one and it wouldnt work on the 1.8l cause it hits the metal part of the timing cover on the block on mine and I was curious if it did the same on yours.
- fowljesse
You have to grind away the block a little bit. I don't know why they made them that way, or didn't fix the design. People have put 150K miles on them, though, with no problems.
- GreenMachine
Yes it does have a lip, and you do need to grind a little bit. I never got to grinding my motor so this pulley was never installed.
