20100316:
- Got to Lancaster at 7pm, enough time to see the car in daylight. Couldn't start it because we didn't have gas, there was no battery, we couldn't get the ignition switch to turn (the key is broken off inside), and there wasn't enough time to tear it apart.
- Got the car onto the dolly by pushing it down the hill (being the smart people we are, we didn't bring a wench). Only took 7 tries to get it right.
- Cut my hand when I rubbed the back tire. Metal! That's not good.
- Stopped at Advance Auto to pick up a jack so we can change the front tires to the back.
- 9:30pm: with some innovative use of wood found in a scrap pile behind the store, we finally got the car off the dolly
- 10:30pm: finally got all the tires changed. Only one good tire on this car, so looks like we're driving a couple hundred miles on the doughnut.
- 11:15pm: previous car owner's buddy drops by and asks how much we gave for it. Gave us advice on how to change the water pump (we decided NOT to cut through the wheel well as he proposed, though). Graciously helped us push the car back onto the dolly (tough with a flat front tire).
- 3am: got home and went to bed, but not after snapping some photos of the car parked outside my house. Will post pics once I retrieve them from the camera.
- We got the car cleaned out of all the junk. In all we recovered a 400watt amp, 6 towels, two pair of shoes, a pack of floss sticks, a rain jacket, a set of sockets, cable and a terminal for moving the battery to the rear of the car, an mx6 haynes manual, an ozzy osbourne cd, some dog crap, $7 and some change, and a tampon.
- We took out all the carpet and started scrubbing down the interior
- We began dismantling the dashboard and disconnected the ignition switch. Once this was done we were able to start the car with a screwdriver!
- The water pump definitely needed to be replaced (bad bearing), so we started taking everything apart. Partway through, we realized in our fatigue that the manual said to take off the timing belts. No!
- Robert had the idea of removing the motor mount and raising the engine up. We were able to avoid having to remove the timing belts (but we did still have to remove the timing belt covers, which apparently are a royal pain)
- We bought a new water pump for $70 (maybe reman would have been better, but we didn't want to take chances with a critical part of the cooling system that takes so much time to replace). That brings the total car value to $300-$7+70=$363.
- The new water pump fit, but we bought the 32mm variant instead of the 16mm. Oops. Went to bed at 1am.
- Went to LKQ at 10am to get a pulley with a 32mm bore
- Found a pulley that fits, but couldn't remove it due to a bent frame
- Tried to drop the engine so we could get the pulley, but it was held in place by the fan shroud. That's quality plastic!
- Got soaked by the monsoon that appeared out of nowhere. Found refuge in a nearby 626. Failed in our attempt to amuse ourselves by removing the cassette tape from the tape deck.
- Grabbed four wheels from an s4 rx7, the pulley, and some lugnuts and went home
- The wheels from the rx7 don't fit; we have to take them back (four bolts, yes, but wrong size)
- The lug nuts don't fit either. They are too fat.
- The pulley, however, does fit. Finally got it installed, pumped up the tires, and went for a spin around 7pm.
- The engine runs a little rich and it backfires. This would be normal for a rotary but not a v6. May be partially due to the gutted cat converter.
- The brakes and wheels are good. There may be an issue with one of the CV joints.
- Blew a hole in the radiator during the test drive. Parked the car and let it "pee" into the woods. I'd been doing this all day but the car had been cooped up in the garage all weekend.
- Planned on replacing the radiator, but ended up spending most of the day picking up a '67 mustang for my roommate. Minimal rust and it runs for $1000. Not bad!.
- Ended up changing the oil and removing the cruise control. No time left in the day for anything else, but I have Friday off next week.
