Rev Limiter once again
Posted: March 24th, 2010, 2:38 pm
Hello I've been thinking about doing the ECU mod (changing the crystal) - and I wanted to know what you think about it?
As far as my opinion is concerned CAI + No Cat. exhaust move the maximum power/torque to the higher values of engine rotations therefore rev limit. should be changed as well...
Looking at the dyno results from serial mx-3 (it's my friends - awesome results just as factory manufactured it) http://img515.imageshack.us/img515/1350/dsc0334d.jpg" onclick="window.open(this.href);return false;
we see that the HP is growing till the end - so probably the power will keep on rising together with rotations - and as we know for example mx-5 1.6 dohc enginge car survive up to 9000rpm without any big problems.
On the other hand many people claim that after Rev limit is reached in mx-3 there is a sudden drop of power - and that CRYSTAL mod leans the AFR mixture... which is not that good...
Finally I have a small question - in mx-3 online manual - ECU is called ECM or am doing a huge mistake?:)
