first my car was starting before
now it doesn't at all it swings over but just wouldn't start
all the lights on the dash are coming on and now i seeing the gas light coming on as well and my gas needle is on the second stroke
all air vacuums have no leaks and all fuses are good
your help would be a great thanks to this problem
in need of help
- Evo_Spec
Re: in need of help
if you seach, there's a lot of great threads about people having problems with this same problem, try searching "no start" "help with engine start" "engine won't start"
but basic things to try and help.
make sure you have all these.
-Air
-Fuel
-Ignition (spark)
-Air
-Fuel
-Ignition (spark)
- Newfie_dan
Re: in need of help
I agree with evo_spec do those checks first off.
