camber settings
Posted: February 19th, 2010, 8:29 pm
ok, i went to get an alignment done, and when we looked at the settings, the guy tells me the camber cannot be adjusted and i need to get camber bolts.
is this correct?
i tried searching and found nothing about the camber in here. the toe and caster are set as close to stock as possible, but i'm riding on 5-6* of camber and have pretty much eatten up 4 tires in the last 4 months (i do a lot of 75-80mph driving for like 3 hours) and it's getting expenssive.
any help with this will help.
in short:
do i need camber bolts?
if not, how do i adjust the camber?
if i do need them, where do i find a set?
the shop told me they could get them for like $160 for the fronts!
i find it hard to believe mazda would make a car that has not camber adjustment, or need of aftermarket parts.
the car is NOT lowered, and is riding on brand new KYB GR-2 shocks.
is this correct?
in short:
