V6 Engine lives long?
Maverick
Post by Maverick »
Hi all!
i've a friend selling is mazda mx3 v6, is a canadian versione, precidia!
It has 225.000 km. I would like to know if, for an engine like this, are they very much or i could do at least 80.000 km with no problems!
thanks a lot, regards! :)
Ryan
Re: V6 Engine lives long?
Post by Ryan »
Well, it won't blow up one day, but if it isn't leaking oil already, it will slowly start... and thats about it. Can you turn a wrench? lots of easy options to swap it out.
And of course it will need some maintenance, probably another waterpump and timing belt
JWMX3
Post by JWMX3 »
Impossible question to answer.
It all depends on how well it was maintained and how hard it was driven over those 225 k
There are ways to tell, compression test, leakdown test, gas mileage, Emissions numbers etc
I owned a probe GT with a KL that had 461xxx kms and ran fantastic. Ive also seen them in the junk yark with less than 200k on the odometer
Maverick
Post by Maverick »
thanks all.
i'll check these things! ;)
Most people don't keep the K8 long, they'll usually swap to a KL long before any problems arrise in a K8, lol.
grimsby3
Post by grimsby3 »
I'm driving a MX-3 Precidia V-6 K8, it has about 320,000km on it and so far (touch wood) no major problems since I've had it, which was around 275,000km except a fan belt and an alternator. Although now I've said this its probably gonna blow up or something thanks to Murphy's law
'95 MX-3 Precidia V6 1.8L, Sony Stereo Deck, 12" MTX Sub w/500 Watt Amp KLZE Swap In the Future!!
fowljesse
Post by fowljesse »
grimsby3 wrote:I'm driving a MX-3 Precidia V-6 K8, it has about 320,000km on it and so far (touch wood) no major problems since I've had it, which was around 275,000km except a fan belt and an alternator. Although now I've said this its probably gonna blow up or something thanks to Murphy's law
You need to come over, and give an offering to our shrine to Murphy that Sarah made!
To the OP, Depending on how your car was treated, it will last until... well I won't jinx anything. Check the compression, plugs, etc.. and do a routine maintenance. If you know a good mechanic (and are not one yourself) have them look at it for tell-tale signs of abuse.
Maverick
Post by Maverick »
i've read that every 60.000 km time belt has to be done to preserve v6 integrity! how can i know it? Of course, except asking it!
That would be 60'000miles, or 100'000kms, but technically that's not true, they are non-interference motors which means that if the timing belt breakes, there's little-to-no chance of valvetrain damage.
fowljesse
Post by fowljesse »
There's really no way to know the life left on the belt. If you need it to be totally reliable, you should change the belt, and distributor. You don't have to change the distributor if it's 96, or newer.
Change the timing belt then use the old one on,,,well um ok,,,,,,,sorry wrong forum.
Maverick
Post by Maverick »
thanks again to all!
now the question is moving around..
why to change engine? ok ok , performances are far far away of the little 1.8 v6, but it sucks so much that anyone do the swap?
i've seen some videos on youtube and it seems really fast and pleasant to drive due to necessary torque at any rpm?
am i wrong?
It's only 130hp. Even back in those days you could get Civcs, Integras and Preludes with 200hp
If you want performance to compete, a swap is really the only way. But if fun is what you want and you're happy with your K8, than so be it, to each their own.
Muzzled
Post by Muzzled »
my Gs has almost 300k on the stock K8....... i was gna swap it but then i found something else for the ZE >_<
she burns oil but still runs like a champ haha... survived my trip to ottawa and back no prob..... and made 650k on 1 tank of gas on the way home.. not bad :P
92, Gs-Ze. KL31 motor/curve neck IM, Cai,Chipped ecu,awr mounts,clutchmasters stage 2 "R",
Se interior,Wrap around spoiler, oem full sides and MS front bumper :)
Maverick
Post by Maverick »
yes, not bad of course! :D
but here in europe fuel consumption is not equal to US!
here 1L of gasoline costs about 2$!
