KL-ZE swap, car chuggs between 1500rpms & 2800rpms
- bbunkerc397
I get a bit of chugging once and a while but not all the time, only when engine hot between 1500 and 2800. Some times the engine light comes on, code "fuel trim malfuction" it clears. When doing the swap I replace two lower o2s bank1 sensor 2 & bank2 sensor 2 the onthers looked ok, new fuel filter, tested fuel pressure regulators, thier is no vacume leaks "smoke tested". I open for suggestions.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
- Newfie_dan
Re: KL-ZE swap, car chuggs between 1500rpms & 2800rpms
weak fuel pump or poor connections at the fuel pump perhaps, or look for corroded wiring at the 02 sensor plugs. I would check that wiring out and see if there is any corrosion in the plugs. also as a slim possibility there could be signal interference from the front 02 sensor if the wiring is to close to the distributor. I had that issue with a escort gt once, signal was not consistent causing some problems.
could it be fuel filter?
- bbunkerc397
Last night I checked the plugs conecting the 02s and wiring around distributor they look fine, today i will remove the back seat and check the fuel sender unit. Also it has a brand new fuel filter when I did the swap, should I put a higher volume fuel pump? Because bigger engine means more fuel? thanks.
