Removing tail light
- mitmaks
Removing tail light
So I need to replace/inspect bulb in tail light. Do I need to take off interior panel to get to screw that holds tail light on?
- _-Night-Shade-_
Re: Removing tail light
Very simple task. No need to do anything with interior. 2 screws on top of the tail light and one on the inner side, after that you need to push it out away from the car to the left/right depending on which tail light it is, there are clips holding it in place.
- mitmaks
Ok, thanks for clarification. I saw a clip thought it needed to come out from back side. Didn't want to break anything._-Night-Shade-_ wrote:Very simple task. No need to do anything with interior. 2 screws on top of the tail light and one on the inner side, after that you need to push it out away from the car to the left/right depending on which tail light it is, there are clips holding it in place.
- Evo_Spec
yeah, loosen the 2 screws, take off the top plastic piece, and give love taps with your palm on the insides of the tail light (length-wise) towards the outside of the car. it should pop right off, if anything its harder to get it back on XD
While you're at it, add some gusto to the plastic piece, I painted mine blaze red while swapping to LEDs.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
