Edit: Delete this thread please
MrMazda92
Post by MrMazda92 »
I can't delete my thread myself, so I request that somebody does it for me. People were seemingly incapable of reading all the posts before replying with "buy new ones" and other quite obviously wise ideas.
Last edited by MrMazda92 on December 27th, 2009, 10:11 pm, edited 2 times in total.
PoisonDrop
Re: Rear Hatch problem(Bad struts?)
Post by PoisonDrop »
I'd say the junker set is bad as well...
Just purchase those new. I've come across some online for around $30 each...
Stay away from the dealer, though, they will charge way too much.
93 MX-3 BP - Worklog
mitmaks
Post by mitmaks »
I got some for mom's car for like $34 shipped on ebay.
MrMazda92
Post by MrMazda92 »
Forgive me if I've made an ignorant mistake, but I was very thorough in examining the ones at the wreckers.
They supported the other hatch very well and had alot of resistance when I took them off. They worked amazingly in that car, like brand new. The problem was they ceased to function at all when I put them in my own car.
Does anyone have an idea what might have happened?
umcamara
Post by umcamara »
Don't worry about what may have happened. Clearly they're no good, get some new ones. They'd been in that car for quite some time, maybe the rotation of the shafts after being removed caused the gas to leak out, who knows...
'98 BMW 328is M-Tech
Feedback Thread
fowljesse
Post by fowljesse »
Was there a temerature difference from when they were on either car? Mine barely work in the summer, and don't work in the winter. Also, if the junk car was an rs, the hatch would be lighter.
MrMazda92
Post by MrMazda92 »
The temperature was the same, both cars are GS.
I didn't spin them around after removing them, I put them in a box and they stayed there for 2 days in my trunk until I installed them.
I don't want to just buy brand new ones because I don't yet know the cause of the problem.
Forgive me if you find this rude but... I won't go out and waste money buying 2 brand new ones when I may well have a problem that ruins them as well. I'd like to be well informed before making any investment, no matter how small. If I buy 2 new ones and have the same problem, I'll be out even more money. I don't like quick fixes; If I fix something, I do it once and I do it right.
umcamara
Post by umcamara »
Man, it's not a complex system, it's a hatch. There's nothing in particular causing the struts to wear out, other than the fact that they hold up a heavy hatch. There's really nothing that could be causing your struts to pre-maturely wear out, as you seem to be convinced is the case.
Don't get new struts, and let your sawed-off golf club slip, and hatch take your head off. Up to you.
Was the hatch at the wrecker missing the glass, spoiler, plastic interior trim pieces, wiper and motor, lock mechanism, or brake light, as most are?
Feedback Thread
MrMazda92
Post by MrMazda92 »
umcamara wrote:Man, it's not a complex system, it's a hatch. There's nothing in particular causing the struts to wear out, other than the fact that they hold up a heavy hatch. There's really nothing that could be causing your struts to pre-maturely wear out, as you seem to be convinced is the case.
Why of course, why didn't I think of that... it was a pair of struts holding up empty air. How naive of me...
Yeah it had everything attached, and as I said earlier(You should read ALL my posts, not just the last 2) They weighed approximately the same amount, as is to be expected. There is no explanation I can think of whatsoever.
I don't pretend to understand your financial situation, but I know my own better than you ever will. I cannot afford to waste money on something that might not work. I put money into things I expect to work, based on known facts and likely outcomes of said facts. I may be new to these cars, but I do not lack common sense. Please refrain from treating me like a child in future, or if you are steadfast in your beliefs... feel free to not post on my thread. Nobody held a gun to your head mate.
mitmaks
Post by mitmaks »
I would've closed and opened hatch a few times on the parts car and see if they were good. I think that they just had enough gas to stay open for short bit and once you got them on your car they couldn't hold it up anymore.
MrMazda92
Post by MrMazda92 »
mitmaks wrote:I would've closed and opened hatch a few times on the parts car and see if they were good. I think that they just had enough gas to stay open for short bit and once you got them on your car they couldn't hold it up anymore.
I put in my original post that I did exactly that... I mean no insult but you guys need to read posts before you reply...
Savin
Post by Savin »
You say it weighs "about the same" but that slight difference is enough. When I had just the RS hatch garnish on my car, the hatch opened on its own. When I had the 92-93 GS spoiler on it, it would not open on its own, but it would stay where you left it. And when i put the wraparound 94+ GS spoiler, it wouldn't stay up at all.
Just a thought.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
MrMazda92
Post by MrMazda92 »
Savin wrote:You say it weighs "about the same" but that slight difference is enough. When I had just the RS hatch garnish on my car, the hatch opened on its own. When I had the 92-93 GS spoiler on it, it would not open on its own, but it would stay where you left it. And when i put the wraparound 94+ GS spoiler, it wouldn't stay up at all.
Just a thought.
I'm a pretty good judge of weights, next time I'll shoot video of both hatches so there is no doubt... since several people seem to doubt not only my vision, but my judgement as well.
So what will happen when I do as several people seem to think is wise and buy 2 new struts... and they fail to function properly? You go "oops" and I get to pay for it? No.
Sorry, but I'm getting impatient... I'll delete and repost this thread with the request that people actually READ the posts before replying.
Savin
Post by Savin »
I was just throwing my own experiences out there to help. Also just as another "info tossing out session" the differences in weight between the 3 hatch "spoilers" isn't much at all. I couldn't tell the difference between the 3 when picking up my hatch.
I guess the help you're looking for is: check to see if the mounting points for the struts aren't messed up (slightly bent, etc). that may have put increased stress on the struts and prematurely blown them? :shrug:
Everything else has been said already....We are only trying to help the best we can though...
'93 MX-3 GS - SOLD!
MrMazda92
Post by MrMazda92 »
Savin wrote:I was just throwing my own experiences out there to help. Also just as another "info tossing out session" the differences in weight between the 3 hatch "spoilers" isn't much at all. I couldn't tell the difference between the 3 when picking up my hatch.
I appreciate the advice on checking the mounting points. That I will do, as I did have trouble getting one of them to thread in. Maybe the hatch was tweaked in a way that I would not notice unless I looked closely for just that.
Locked
