k so....
just like everyone else, im havin a cooling problem with my car.
i can start the car, have it idle for 30+ mins, doesnt overheat, but doesnt blow warm air.
as soon as i start driving, it blows warm air, but the temp guage goes right down to 1/8 above the "C" on the gauge.
anyone know what my problem would/could be?
i do believe it is my thermostat. but im just trying to get a 2nd opinion.
thanks for the help
Common Cooling Problem, But with a twist...
- mitmaks
Re: Common Cooling Problem, But with a twist...
possible air pocket in system. Have you flushed system before? New thermostat might fix problem, they're not too expensive.
i havnt fully flushed the system, but i changed out the coolant and now the temp guage wont go above 1/4 mark. even at idle and going 150kmph down the highway in -35 degree weather.
i made sure there were no air pockets...
i got a new thermostat waiting to be put in, but i cant find a walkthru on how to do it. (still learning about cars)
- navymx3
I saw your problem, and looked through the workshop manual for the K8, if thats what you have, here is the removal, and installation for the thermostat.
http://www.mx-3.com/manuals/showimg.php ... E2-008.gif
for the b6
http://www.mx-3.com/manuals/showimg.php ... E1-009.gif
Hope that helps you out bro.
for the b6
93 Mazda MX-3 GS V6 24V 5 Speed
Ah, a newbie using the online manual. Brings a tear to me eye.
- navymx3
Haha, your hilarious dani
i was reading it for like an hour, and I already learned so much
I cant believe I wasnt using that before, answered a lot of my questions, more people need to know about it and have up front access to it. I love this thing. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- Hoodzy
All newbs should have to read it and answer a test before they are allowed to post.
1995 Creek Mica Blue GS
- atomic froster
yea i have the same prob, goes up to temp, but when im beating on her on the hwy the temp gauge drops low. i also see a small drop in power, i just figured it was something to do with my klze swap and no new ecu yet.
If you're sure there's no air, then you can see if you're thermostat is working by placing your hand on the upper radiator hose. If your thermostat is open, that hose will be hotter than...well you get the picture.
But I do have to say that sounds like an air problem. The heater blowing cold then warn is a tell tale sign...
I suppose it could be both? Couldn't hurt to replace the temp sensor as well. They're pretty cheap, and then you'll know you're getting the correct reading on the gauge...
93 MX-3 BP - Worklog
