Welbro 255lph for Mx-3 KLZE
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
DaMN
Post by DaMN »
Hello, hope it's the right forum for posting this question.
I own Mx-3 KLZE stirght neck '94.
My fuel pump decided to start dying (got "low fuel tank" light even if the fuel tank is full), I just got me in a good price the Welbro 255lph.
Havn't installed it yet 'cause I don't know for sure it'll be good for my car.
I don't intend to add turbo or even FPR, just to replace the original fuel pump in new one.
Can I install the Welbro 255lhp fuel pump in my car without adding anything and it'll work as the old original pump?
Thanks.
hgallegos915
Re: Welbro 255lph for Mx-3 KLZE
Post by hgallegos915 »
My ze ran fine with it, i remember I removed my turbo for a few months and drive the car like that. I got around 25 - 27 mpg. Some members have reported that their engines ran a little bit rich but was fixed with an afpr. Only way you can really tell if its running rich or not, is a wideband o2 sensor.
-hec
DaMN
Post by DaMN »
Hey, first of all thank you for your answer.
I can still return it if it's not 100% like the original fuel pump, but i can't install it to check 'cause then the seller won't get it back.
From your things I understand it's better for me to go and buy the original fuel pump, that's the only way I can be sure it's 100% work as the old one.
hgallegos915
The original fuel pump may be more expensive (if you buy it local)
the klde fuel pump will work as wel too. I say install it and check your average miles per hour. Also dont forget to replace the hose that connects to the pump, mine lasted about a year then it popped from the pressure that the walbro pump created.
-hec
WhiteFinish
Post by WhiteFinish »
I believe the walbro will give to much pressure to your standard fpr and break it.
Just go to the junkyard and get a used one.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Slammed6
Post by Slammed6 »
Did you get a 255 Low Pressure or 255 High Pressure?
I ran a 255 High Pressure, with all stock fuel system and the car ran fine, I ran it for over 2 years. It will be on the rich side but won't hurt anything.
Post by wytbishop »
Changing the fuel pump won't fix your fuel gauge problem. That is caused by the float not floating. When you get the Walbro pump you have to attach your stock pick up and float assembly to it before installation.
Your float probably has a leak and is full of fuel.
hppwdn
Post by hppwdn »
I ran a 255 on my stock FPR on my ZE for a long time. Probably close to 2 years if I remember.
I agree with bishop though, it doesn't really sound like a fuel pump problem.
DaMN
Post by DaMN »
I'm pretty sure it's a fuel pump problem.
I got this warning "low fuel", I filled my car with water, not on purpose the fuel was diluted with water.
Me and my friend empty the fuel tank and saw water and oil.
Also on right turns the engine shuting of for a sec or two, it's not getting any fuel.
When I'm at the last querter of fuel, the pump having problem pumping fuel into the engine.
That's why I'm pretty sure it's a fuel pump problem, don't know if it's anything else, but the fuel pump is dead for sure.
BTW I got the high presure 255, but i'll go and replace it with the stock one, just to be on the safe side.
Post by wytbishop »
Changing the fuel pump is probably a good thing. But it will not necessarily solve all of those problems. Make sure you inspect the pickup and the float before you reinstall them. The fuel starvation issue could be because of a dirty sock. When you drained the tank did you actually clean it out? there is often a lot of crap collected in there...that could also be contributing to your problem.
Ryan
Post by Ryan »
May as well change the filter in the bay, too. Not an expensive part, and a good idea if you're having fuel problems. I've seen them jam packed full of dirt, from the crap in the tank as wyt mentoned.
DaMN
Post by DaMN »
Tomorrow I'll open and see what's going on inside.
Also I'll chack everything you guys said, thank you.
I'll update here.
Return to “Engine Electronics/Tuning”
