will this wheel bearing hub fit?
Posted: November 14th, 2009, 8:59 pm
http://cgi.ebay.ca/1991-2002-PROTEGE-ES ... 3997wt_754" onclick="window.open(this.href);return false;
it says it only fits the mx3's with drum brakes, i have a 1.8l with disc brakes. all the other wheel bearings ive seen on ebay say they will fit disc or drum brakes. is there anything special about this hub or should i just order it? this one works out to be able $20 cheaper after shipping then the other ones on ebay...
http://cgi.ebay.ca/WHEEL-HUB-BEARING-MA ... 3035wt_958" onclick="window.open(this.href);return false;
