Really odd 5 speed problem...
Posted: November 12th, 2009, 8:18 pm
by Work-N-Progress
I have a 1993 GS SE and for some reason, sometimes when I go to put it in first, the shifter actually drops.. almost like its coming off some sort of hinge or something. I have no clue what the hell the problem is. Has anyone else dealt with this issue? Any insight or help would be appreciated.
Re: Really odd 5 speed problem...
Posted: November 12th, 2009, 8:20 pm
by jmdearras
Sound like your shifter mount is falling apart.
Posted: November 12th, 2009, 8:22 pm
by solo_ryder
Common issue. There is a bracket under the car that holds the shifter up in place. After time the rubber hangers that hold it in corrode and deteriorate and the shifter will fall down. Best thing to do is go to a wreckers and get another shifter stabilizer bar or make a WTB post to see if anyone has one locally.
There was also anti drop brackets made, but IDK if they are made anymore. Do a search
Posted: November 12th, 2009, 8:36 pm
by DaBob94MX3
I had the same problem with my 94 and personally since at the time I had a major lack of funds I tack welded mine to my car. Though i had to cut and tack it three times because the first time i didn't think about placement so I wasn't able to shift into reverse. So if you choose to do that be very precise but make sure not to weld to much or you'll never be able to get it off.
Posted: November 12th, 2009, 8:40 pm
by Work-N-Progress
To be honest, im 19 and have NO CLUE how to weld lol. I sell cars and talk... thats about it :P If you had to rate the difficulty of changing the bracket, where would you guys place it? Would common sense get me through, or is there alot involved in fixing it?
Posted: November 12th, 2009, 8:47 pm
by Dali
all i did was lift it back into place, drilled 3 holes to run bolts/washers and nyloc nuts thru. its been 4 years and it still is in place. even survived getting hit.
Posted: November 12th, 2009, 9:04 pm
by umcamara
Those anti-drop brackets are still available, the guy had some as of a couple months ago. I didn't bother with the bracket or getting a new control rod assembly.
I removed the control rod and used a good rubber epoxy and let it set up for a good day. Haven't had an issue since.
Posted: November 12th, 2009, 9:17 pm
by Work-N-Progress
If anyone happens to have, or know of a How To or have pictures, SOMETHING I would appreciate seeing it. I really dont know what the setup looks like. I havent pulled it apart yet. Help is always appreciated though.
Posted: November 12th, 2009, 9:27 pm
by umcamara
Have you been formally introduced to the search button at the top of the page yet?
Search button, meet work-in-progress; work-in-progress, meet search button. There we have it.
Posted: November 12th, 2009, 10:30 pm
by wytbishop
I can help you with that too.
