Dying tan dashboard.
I recently got a mint TAN dash to replace my cracked black dash. Now everything I have is black so is it possiable to dye or any perment solution to changing the dash black. I am looking for the best quality solution to this. thank for the help.
- Ryan
Re: Dying tan dashboard.
Have you considered leaving it tan? Someone else has a tan dash and wants to leave it 50/50... I think it may look pretty sweet actually.
- mitmaks
your local auto body supply store should have vinyl paint that's made especially for vinyl/plastic parts
- mrmike420
Vinyl paint… you can buy it at pretty much any hardware store...
~FUeGo~
92 MX-3 GS, 5spd, Black Metallic, Tokico ZX2 Struts, Eibach Springs, Sylvania Silverstar Ultra's, K&N A/F, Suzuka S/S Brake Lines, KGS Dual Tip Muffler, Dynamat Extreme Trunk Kit
I painted my tan dash black... I'm not sure if I used "vinyl" paint but I have had no issues for 3 years.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
There is a product that upholstery shops use specifically for this purpose. Itis typically applied with an air brush, but I'm sure you can find an alternate method.
An upholstery shop would probably color your dash inexpensively if you brought it to them already removed. Probably do a better job than you could as well.
