Locating a Valve Cover Gasket
- MX3-4U2NV
So, I was changing my plugs today, noticed oil in the spark plug holes of 4 out of the 6 plugs. One had so much oil, it was the height of my plug wrench.
So I am in need of a Valve Cover Gasket.
Anyone have any cheap locations within the GTA where I can find one?
And how much do they go for anyways?
Re: Locating a Valve Cover Gasket
In canada, you HAVE to go to mazda, prepare to shell out between 35-45 for the gasket.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- mitmaks
get one on ebay. http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT" onclick="window.open(this.href);return false;
Can those be trusted? I've never bought a gasket from ebay.
- mitmaks
why can't it be trusted...well I just got mine last night and looks just fine to me, also came with grommets. Now its pita to change rear one but I saved money.93vtecklr wrote:Can those be trusted? I've never bought a gasket from ebay.
Is it genuine mazda parts? I kinda got a hate-on for jobber products.
A few guys have had oil leakage problems with the aftemarket valve cover gaskets...
- MX3-4U2NV
Also, I am guessing I should change the intake manifold gasket too, seeing as I'll have that off as well?
Any other things I should do/look for while doing this?
Phenolic thermo spacers from outlaw engineering.
- mitmaks
you have to know how to install it properly. All bolts need to be torqued to spec and new grommets have to be used. Also you need to use gasket maker on it.Nd4SpdSe wrote:A few guys have had oil leakage problems with the aftemarket valve cover gaskets...
- MX3-4U2NV
Huh?93vtecklr wrote:Phenolic thermo spacers from outlaw engineering.
EDIT:
So, so far I will need front and rear Valve Cover Gaskets, Intake Manifold Gasket, and Phenolic thermo spacers?
And I can get stuff from Napa?
- mitmaks
don't separate throttle body from intake manifold and you won't need that gasket. You just need to replace valve cover gasket and phenolic spacer is optional, you can just use regular intake manifold gasket.
No, phenos you have to get from outlaw engineering, google them, I just think it's something you should do while you already have the manny off. I'm pretty sure you need to get your gaskets at mazda, unless you choose ebay sellers who might have genuine mazda gaskets. But Colin ?used to/still does? work at a stealership so he'd know better than me.
Their problems were fixed with a genuine Mada gasket. No way should you need a gasket maker with those..mitmaks wrote:you have to know how to install it properly. All bolts need to be torqued to spec and new grommets have to be used. Also you need to use gasket maker on it.Nd4SpdSe wrote:A few guys have had oil leakage problems with the aftemarket valve cover gaskets...
