The Good
I put in a different Transmission with around 74k miles on it.
New clutch about 8k miles ago.
New Cork sport Shifter Bushings
B&M Short Shifter.
Motegi Racing Rims
Catback Exhaust
Altezza Tail Lights (silver)
Front and Rear mud Guards
Tires still in decent shape
The bad.
-Could use some body work and paint
-There are some leftover holes where one of the previous owners mouted a body kit.
-The Fenders need to be realigned, previous owner backed over a curb and ruined the body kit and fenders.
I belive the current set are off a different car
-On the passenger side the running board is dented in.
-There is an exhaust leak (toward the front of the car)
-The Front Left Running light needs a new blub socket.
-Needs rear speakers. (bought it without them and never put a set in)
-Horn doesn't work
-Drivers side window wont go down. (The switch could be broken. It doesnt work on the passenger Window either. But the switch on the passenger side will put down the passenger window)
-Sun roof isn't easy to open (motor still works)
-Passenger Side Auto seat belt is broke.
-A/C worked untill a line near the air cleaner cracked. (a few weeks ago)
-It has a funky air cleaner (i've never seen anything like it) looks like a really really short cold air intake.
-The rubber mounts that hold the shifter in place have worn out, but still drivable
![Image](http://i22.photobucket.com/albums/b336/HeadBeard/DSCF0008.jpg)
![Image](http://i22.photobucket.com/albums/b336/HeadBeard/0102080104010103112008082782a65326b.jpg)
![Image](http://i22.photobucket.com/albums/b336/HeadBeard/01020501030201040320080827fc252dcc3.jpg)
![Image](http://i22.photobucket.com/albums/b336/HeadBeard/DSCF0021.jpg)
