Questions on removing throttle body
ive tried the search button but didnt have any luck finding an answer i was looking for...... i was wondering if you ahve to relieve fuel pressure before removing the throttle body on a 92 mx3? if so how do you do this on these cars?
- Savin
Re: Questions on removing throttle body
you don't have to relieve the pressure.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
- umcamara
You will want to pick up a new TB gasket before you remove it though. Around $10 at the dealership.
- vansolrick
If you can not find a gasket in time from local providers, using gasket maker/paper, to cut out and make your own, and some RTV silicone will work just fine. I used it when I replaced my TB with a ported/polished one. Works fine and I don't have any leaks. If you choose to do it this way, make sure you allow the silicone about 14-24 hours to dry depending on how dry it is over there before driving or else you will end up sucking it clean thru and into the intake manifold.
Good luck!
Good luck!
