zero spark? KLZE
Posted: July 25th, 2009, 11:36 pm
by studboy13
So I was redoing my radiator coolant lines and i happened to spray coolant pretty much everywhere above the tranny. then the car stopped sparking, still turned over and everything. so i assumed my coil shorted so i went out and did the HEI mod. everything is hooked up correctly and now im back to where i started. still no spark. what should be the next thing that i check? any and all help would be greatly apprciated.
Re: zero spark? KLZE
Posted: July 26th, 2009, 9:42 am
by Nd4SpdSe
Well, if the coil is gone and you did just the HEI, you still need to do the external coil along with the HEI. HEI just replaces the ignitor
Posted: July 26th, 2009, 12:54 pm
by studboy13
sorry for not specifying, i did the external coil as well
Posted: July 27th, 2009, 5:46 pm
by Nd4SpdSe
What did you use for disty? You put a tower on your stock K8 disty cap, you use a PRD cap or you using a ZE disty?
Posted: July 28th, 2009, 1:45 am
by studboy13
tower on the stock K8 cap
its in there pretty good
Posted: August 1st, 2009, 4:07 am
by studboy13
can someone please help me
this is killing me
Posted: August 1st, 2009, 8:14 pm
by Daninski
Try disconnecting the neg. from the battry and depress the brake pedal for 15 secs. I had to do that to reset my ECU. You may of shorted out the system with the coolant
