could anyone help me out in finding what they are for its a 93 rs also has an alarm installed
i am also having a starting issue it takes me at least 10 times turning the key to start before the starter wants to kick on and sometimes it starts first try i already swapped the starter for a 1yr old one
In no particular order, the wires from that green harness are for:
Rear washer motor, shift lock actuator
ABS control module
Buckle switch
Cargo compartment light
Rear wiper motor
Left rear turn signal
Right rear turn signal
Door pin switches
Taillights, license plate lights, rear side marker lights
Red w/ white stipe that goes into the green harness is either to ABS control module or door pin switches
That being said, those cut wires simply look like aftermarket wires for a remote starter or something similar. Typically the door lock/unlock wires from a remote starter are green and brown.
Check under that electrical tape where the wires are, the ends of those wires are probably spliced into those harness wires for alarm door pin input and whatnot.
'98 BMW 328is M-Tech
