Wanted:96 auto k8 gs turbo kit.
Re: Wanted:96 auto k8 gs turbo kit.
You also want to blow up your auto trans too?
- solo_ryder
Lulz thread of the year
Common guys,lol. What could I do to my car to get more hp and torque? Besides going standard,although I have really been considering that.
Thanks
T.
I guess and engine swap to the kl-ze?...hehehe
Does anyone on here have one?
Thanks
T.
Tineke 96 mx3 v6 black beauty
ummm probly 80% of the ppl here have a ZE.... I find there more common then the 1.8L K8....
You need to do a little reading before you get all gung ho. Start with the V6 FAQ section. Learn a little bit about your engine and the ZE engine and what's involved in swapping them. In doing so you will learn a lot about the weakness of your auto tranny and why people get rid of them as well as what's involved in going turbo.
Okay,thats so much for the info. I have been searching forums. I get lost sometimes as people post in improper forums ect. But I will continue. Thanks for your help.
yep keep researching and browsing the worklogs... stock klze + manual tranny will give you the power you are looking for
KLZE will blow the trans too.tineke wrote:I guess and engine swap to the kl-ze?
It's about power, the K8 stock trans will not hold up to any power adders, swap or turbo. That is your weekest link, and those are the only ways to get more power. With bolt ons, you can get about another 10hp
- solo_ryder
Where r u located? I'd start with a 5 speed swap and get some bolt ons for a few more ponies
I'm in greater vancouver area b.c...so..the KL-ZE only works with a manual transmission I am assuming...Automatic is for sissies. ..I should just look into buying an entirely different mx3, the one I actually want..it would probably cost around the same amount as swaping everything...?
I learned how to drive standard in two days at my stepsisters place ONLY because she broke her hand and I had no choice,unless we wanted to walk everywhere in a town that is 40 min from kamloops..the nearest actual city,lol..It was a subaru tiny 4x4 suv/car,lol..it was a riot..I'm sure you all recall your fist time learning a standard,LOL. decisions decisions.
Even if you can find a POS GS 5sp donor car you can easily get everything you need to switch to manual. If you can get a bit of money for your Auto car though, finding a nice GS 5sp would be the easiest way to get where you want to be. The engine swap part is pretty easy.
A word of advice. If you're planning to swap in a ZE, look for an OBD1 car. It will make your swap much easier. Otherwise you'll have to make friends with Daninski, the OBD2 swap genius.
- solo_ryder
Where abouts? I'm in white rock/south surrey. Pm metineke wrote:I'm in greater vancouver area b.c...so..the KL-ZE only works with a manual transmission I am assuming...Automatic is for sissies. ..I should just look into buying an entirely different mx3, the one I actually want..it would probably cost around the same amount as swaping everything...?![]()
Okay thanks for the advice everyone..I will keep my eye out for a donor car or just the one I want...............I am in Langley.
