will 225/50/16 fit?
Posted: July 12th, 2009, 10:33 pm
by mazdamx3freak
will a 225/50/16 fit without problems? or can someone suggest another 16in tire size?
Re: will 225/50/16 fit?
Posted: July 13th, 2009, 12:42 am
by solo_ryder
That is to tall of a profile. 215 45 16 is a good size imho.
205 50 is the right diameter for 16s so since you are goin wider then u should lower the sidewall size. 225 45 will also work, but uncommon size. Try 205 50 or 215 45.
205 45 is abit to small imo
Posted: July 17th, 2009, 9:17 pm
by Trevor
Actually 225/45/16 Are really close to stock hight. I used that size when I had 16"rims. With the proper offset you should have no problems
Posted: July 20th, 2009, 12:05 pm
by rekognize
Get 215/45/16
