Coolant remperature sensor on the ZE
hey guys r u running the ze CTS or the k8 one
- solo_ryder
Re: Coolant remperature sensor on the ZE
I am running a ZE one, the 2nd sensor if that is what you are referring to.
I am running it as that is what is on the motor. I wired it into the ECU, and that fixed that fan issue. However, last I checked I was still running a code for a CTS sensor..
wat
If you wired it right, you shouldn't be getting a code. After sorting mine, I checked codes, and all was clear. Granted it didn't work as advertised, but yeah...that's another story.
BTW, I think Mazda used the same coolant sensors for all their K motors.
- solo_ryder
Yea I think the coolant sensor is the same.
I will run codes again soon, the fans are working right now so I dont really care.
Hey, are they coming on at the right temperature? Noticed anything odd about their operation?
- solo_ryder
Seem to be yea, car hasn't overheated.. They seem to work fine as far as I am concerned.
I noticed your thread before about overheating.. You fix that?
Do you have MSN? Add me up
Well, I sorted it by swapping in a '95 KL85 ECU, so single sensor, and now it works properly. My guess is my black fan sensor is borked. I barely use MSN...
