![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10516.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10518.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10522.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10525.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10526.jpg)
Now for the IAC Block Off plate. I had one made since my IAC hasn't been hooked up in forever. It fits perfect and really fixed up the idle from the unhooked IAC.
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10510.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10511.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10529.jpg)
![Image](http://www.iceyrecords.com/drew/mx3/2009-05-17_NewRimsTires-IACBlockOffPlate/web/SDC10540.jpg)
Function over form. I'm amazed they fit in the wheel well. They stick out a tad, but not really any worse than my old set. I would be afraid if I saw a little econobox with tires like that in my rearview.projectzemx3 wrote:wow those tires are huge....
seboroth wrote:Are those the Yokohama S-Drive's? I've got a set on mine and love em.
Sexy car btwhppwdn wrote:Rims are Rota Subzero 17x7.5 (16 lbs) and Yokohama S.Drives in 245/45/17 (24 lbs).
Ok, that explains it. I was gonna be like, Holy buckets!!! How did you get those to work without rubbing!!hppwdn wrote:Nope. It was a very precise project to make tires that big fit. You can't do it without a full coilover suspension, and even then you have to set it up properly so the perches sit above the widest part of the tire. It took a lot of adjusting to get it lined up.
