Codes with no TAT pin?
Posted: May 17th, 2009, 11:25 am
1993 MX-3 1.6 AT
I'd like to check the codes my automatic transmission is throwing... but when looking at the diagnostic connector there is no TAT pin. There is a pin for TEN for engine diagnostics, though, and when that pin is grounded, my Check Engine light will flash my codes for fuel/emissions (like if I disconnect the MAF sensor).
Is there another pin to ground to flash the ATX codes through the instrument panel?
Thanks,
dan s.
Thanks,
dan s.
