is the whiteline sway bar for me??
Posted: May 4th, 2009, 4:03 pm
by jamesmx3
I have zx2 gas struts and -45mm springs, the ride can be harsh on cr@p roads, when i hit pot holes ect, will the sway bar make it worse or just keep it more stable round corners??
Re: is the whiteline sway bar for me??
Posted: May 4th, 2009, 4:25 pm
by yence
The whiteline rear swaybar will reduce bodyroll and understeer, all without comprimising the ride quality. Sounds like it's for you
Posted: May 5th, 2009, 6:29 pm
by 96mx-3
is the 96 bar the same size as the whiteline ?
Posted: May 5th, 2009, 6:31 pm
by Flyer
My 1996 swaybar measured 20.XXmm...don't remember if it was hollow or solid though...
Posted: May 6th, 2009, 11:47 am
by jamesmx3
is that the difference with the whiteline one, that its solid so it should be stiffer?
Posted: May 6th, 2009, 2:00 pm
by yence
If not mistaken, the whiteline is 22mm.
Posted: May 6th, 2009, 3:57 pm
by fowljesse
Yeah, the Whiteline is 22m, and solid. It made a difference on my car, and I have everything else done. I don't know about pothole resilience, though.
Posted: May 6th, 2009, 6:23 pm
by 96mx-3
ok thanks. . i guess i miss read info somewhere..
