I posted this on clubprotege but i thought id try here too:
ok, im looking for a new turbo, I have a 95 MX-3 BPT swap on MSII hopefully running one of the group buy topmounts bonestock internals, i was on a GT28r running about 18psi but recently sold it. my goal is to get as close (hopefully to) 300whp on stock internals as I can. Im looking into Borgwarner turbos but im not sure what type of S200 i would need. But if I go garrett i was told to get a GT3076r but im not sure.
i kind of want a Vband turbine housing ($50 more) and a anti-surge compressor (+$65)
GT3071R
· Turbine Wheel: 60mm w/ 84 trim
· Comp Wheel: 71mm w/ 56 trim
· Comp Hsg: 0.50 A/R
GT3076R· Comp Wheel: 60mm w/ 84 trim
· Turbine: 76.2mm w/ 56 trim
· 500HP+ Capable
Turbine A/Rs for both are -> .63, .82, 1.06, .78(only in twinscroll), .48
input?
http://www.frsport.com/Ball-Bearing-Series_c_228.html" onclick="window.open(this.href);return false;
im not buying from frsport but they have garretts listed and variations.
what do you guys think would be best? also what injectors do you think I'll need, i have GTX, 460, and 550's already, do you think i will need bigger?
New Turbo (need input)
- mazdax3speed
Orange 95' BPT GT28r, MSII on the way
- mazdax3speed
Re: New Turbo (need input)
bump!
BorgWarner S256 with a .55 turbine housing?
