passenger side bumper sag, fixes?
- Evo_Spec
hey guys my bumper is a bit lower on the passenger side causing a gap under the headlight.
i've seen other people with this problem also and was wondering if anyone found a fix for it, or knows how to fix it.
thanks
a picture of what it looks like
looks a little better with my jdm's in because of the small lip on the headlights holding it up
thanks
Re: passenger side bumper sag, fixes?
thats weird cause it lines up with your passenger side fender pretty well.
try taking the bumper cover off and then moving the actual bumper farther up on the pass side. you might have to drill out those two holes.
NEED PARTS INSTALLED? PM ME!
- Evo_Spec
there's actually a small gap towards the front of the fender, if i push it up, it all lines up correctly, i was wondering if maybe a support bracket broke or something
thats possible too. there is a thin metal strip that runs along the bumper, they get rust over time and become pretty weak. maybe it broke? on that side. it makes it look like your car has a black eye tho which is pretty sick.
- Evo_Spec
thats what my friend said tooprojectzemx3 wrote:it makes it look like your car has a black eye tho which is pretty sick.
- Evo_Spec
i kind of fixed it, i found out the screw behind my signal light was missing.
looks a lot better now IMO
i also smoked my signal lights ^_^
a little dirty here
a little dirty here
I have to adjust my front bumper prior to installing spyder projector headlites. Can anyone tell me where the attaching bolts/screws are located. Thanks
- Evo_Spec
-there's one screw behind each turn signal (well in my case one XD)Daninski wrote:I have to adjust my front bumper prior to installing spyder projector headlites. Can anyone tell me where the attaching bolts/screws are located. Thanks
-two 7mm bolts on the sides closer to the tires
-2 10mm bolts and 2 10mm nuts by the hood release (10 mm nuts under the metal brackets of the 10mm bolts)
-2 10mm bolts on a small metal bracket under both the driver and passenger side (you'll see it when ur looking under)
that should be everything, i didn't see the screw behind the turn signal which is what messed me up
Hey thanks for the info, I don't want to install the projectors untill the bumper is bang on.
maybe like projectzemx3 said u can try drilling a hole closer to the head light and add an extra bolt (maybe with plastic clip or something) for more protection/ better positioning
I had to drill a new hole just below the existing one behind the turn signal light. I also added a piece of plastic bread board held in place with epoxy just under the bumper skin at the head light. Mines good now.
