(FS)- JDM MX-6 KL-ZE LSD DIFFERENTIAL (G25M-R)
JM1EC-V6
Post by JM1EC-V6 »
Genuine Japanese LSD Diff from Mx-6 E-GE5B KL-ZE DOHC (From 62 450km F.C.).
Includes diff & driver's side tripod joint end (to swap on your own shaft).
Use your ring gear with top-grade bolts only & loctite (red).
Only needs jack-shaft (passenger axle) machining to work (like 200$ in machining), copy the existing shaft with different spline count.
Asking 100$ CDN for it. Best for the guy who has the time to get the shaft machined, Genuine & rare Mazda JDM Part !
Pictures upon request, ask at
drd_tuning@hotmail.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
JM1EC-V6
Re: (FS)- JDM MX-6 KL-ZE LSD DIFFERENTIAL (G25M-R)
Post by JM1EC-V6 »
Update: Pictures.
1110Kg
Post by wytbishop »
Do you need bushings? Interested in dealing?
Towona
Post by Towona »
Anyone know for sure if this would fit a BP's G25 trans?
mx3autozam
Post by mx3autozam »
Do you still have this. Really intereste and have money for it in hand.
93 Mazda MX3 KLZE Turbo
JM1EC-V6
Post by JM1EC-V6 »
SOLD
1110Kg
