HELP HELP Just finished k8 swap but wont turn over
evomx
Post by evomx »
HEY HELP ME! lol I just swapped my K8 and it will turn over but will not start. When it turning over it is making a squeeking noise from one of the cylnders. Any one have any ideas?!? engine was sitting for a couple of months but i doubt that hurt it.
projectzemx3
Re: HELP HELP Just finished k8 swap but wont turn over
Post by projectzemx3 »
did you change the timing belt?
NEED PARTS INSTALLED? PM ME!
evomx
Post by evomx »
no i didnt just swapped the belts attached to the alt.
projectzemx3
did you hook your fuel lines up correctly? not backwards? are your spark plug wires in the correct firing order?
evomx
Post by evomx »
I am going to check the fule lines in the moring but i belive they are connected correctly. I also belive the spark plugs are in the correct firing order. I almost seems like it is not getting fule. also this engine has not been ran for about a year. I know the fuel pump works. I do not have the exhaust hooked up as well at the o2 sensors but i dont belive that will make a difference. I am going to check the compressions in the cyl as well if i am even getting a spark.
evomx wrote: When it turning over it is making a squeeking noise from one of the cylnders.
I think a mouse may of crawled into one of the cylinders. Don't laugh, it's possible. :) In this case I'm just kidding.
